gupta
Junior Member level 1
- Joined
- Dec 12, 2004
- Messages
- 19
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- karachi, pakistan
- Activity points
- 237
aza_chomey said:i was also need for some help on an FM Receiver circuit and all the stuff to build the project of fm receiver.. plz help me..
metal said:Hello
You can use this link v:
Bye
Added after 8 minutes:
Hello
Go to **broken link removed**
choose receiver circuits, and then TDA7000 RX.
I built this one myself too, it works good, but the telescopic antenna has to be a good one, and the power supply should be well regulated.
If you build it, let me know, because some problems that are easily solved will appear, on my side, I solved them all.
Regards
