Jul 9, 2007 #1 satya_vijayawada Full Member level 2 Joined Aug 17, 2005 Messages 121 Helped 22 Reputation 44 Reaction score 11 Trophy points 1,298 Activity points 1,948 hi i need some circuit idea for bellow specification input voltage: 14-16VDC output voltage: 1). output 1: 30Vdc@100mA 2). output 2: 30Vdc@100mA 3). output 3: 30Vdc@100mA 4). output 4: 30Vdc@100mA Each output ground is isolated regards satya
Jul 9, 2007 #2 A A.Anand Srinivasan Advanced Member level 5 Joined Oct 15, 2005 Messages 1,792 Helped 257 Reputation 514 Reaction score 39 Trophy points 1,328 Location India Activity points 10,678 Re: smps ic selection you have posted for an smps ic... r u looking for just the control ic or u r planning to build a smps of your own?? also i find all the 4 outputs you are asking for are the same.... please clarify on this...
Jul 10, 2007 #3 satya_vijayawada Full Member level 2 Joined Aug 17, 2005 Messages 121 Helped 22 Reputation 44 Reaction score 11 Trophy points 1,298 Activity points 1,948 Re: smps ic selection sorry i am planning to build a smps four outputs voltage is same but i need each out put isolated(ground also) pls help me............. regards satya
Jul 10, 2007 #4 J Jepeto Advanced Member level 4 Joined Oct 9, 2006 Messages 107 Helped 10 Reputation 20 Reaction score 2 Trophy points 1,298 Activity points 1,817 Re: smps ic selection Linear Application Note 66 power circuits http://www.linear.com/pc/downloadDocument.do?navId=H0,C3,P1164,D4155 TI Reference Design Cookbook Power Management Products http://focus.ti.com/lit/ml/slub009/slub009.pdf Power Management Selection Guide **broken link removed** National Semi Power Products Selection Guide **broken link removed**
