Help me build an ASYNC ALU
the_phoenix
Newbie level 6
hi guys.....after some hectic work....i'm back at my own work.
I need to work on a project for my final graduation .After long thought and discussions, i have come to the conclusion tht i can work on a project in the field of "ASYNCHRONOUS CLOCKLESS UNITS"......basically, i wud like to work for optimising such combinational circuits using vhdl for say hazards or other probs with asyn ckts.
Now, since my knwoledge and reading in this filed is pretty limited, i need u guys to suggest ways to proceed in 1)designing a good enough ASYNC system
2) optimising it (with vhdl)
i got the suggesion of going in for an async alu where the units work using handshake signals. while i understand what i need to do, i have absolutely no idea as to how to 1) build an asyn alu 2)use HS signals.
any pointers in this regards will be greatly appreciated. even onlline stuff is welcome.
I know this is a lot to ask for, but if u can plz contribute whtever u can, beleive me, it's priceless !!!
thx....cheers
Gunship
Member level 2
Re: clockless!!!!!!!!!!
thx....cheers
Ouch! Why do you want to torture yourself like that? FPGA is NOT designed to do async
circuits.
Now, that is not to say it is impossible. I've seen some pretty impressive thing others
have done. Such as a CPU, which has an ALU inside of course. Here is the link
https://www.opencores.org/projects.cgi/web/aspida/overview
You can go to their web site and take a look
https://www.ics.forth.gr/carv/async/
I used to have a detail paper about the theory behind do async in an FPGA but I don't
think I can find it now.
Good luck,
Gunship
