Help me build a magnetic door system controlled by 8051
devilmp4
Junior Member level 1
hi all ,
I have encounted problems in building up the magnetic lock device circuit, controlled by 8051.plz enlighten me if anyone know.
thanks
pranam77
Advanced Member level 5
INDIA
magnetic door lock schematic
I had built and worked similar project using ATMEL 89C52 and RFID bought from united77.com. The relay on board can be connected to any electromagnet to lock the door. they provide all details including schematics, PCB's and components with project description. Hope this will help you. The said kit is also available without RFID option. Chekout their website.
devilmp4
Re: Magnetic door system
Thanks for ur reply , but i am required to use micro processor 8051 to control the magnetic lock to energised or de-energise. i cannot use the ATMEL 89C52 that u mentioned. :(
amol_shah
Full Member level 3
Nasik
    devilmp4
devilmp4
thanks for ur reply.:) The magnetic door lock nid 12v - 24v .8051 give only 3.3v but i nid 12v.how do i increase the voltage?is there any circuit that can be use in this situation?
amol_shah
Full Member level 3
Nasik
    devilmp4
devilmp4
thanks for ur reply .the magnetic lock require 12-24 v and around 450ma of current.
amol_shah
Full Member level 3
Nasik
use 2N2222 transistor instead of BC 547, 2N2222 has collector current of 800ma
    devilmp4
devilmp4
thanks for reply.can i use 2N4307?Because my school dont provide 2n2222 , but there is 2n4307.
Added after 2 hours 5 minutes:
erm mine teacher ask me test with relay RY5WFZ-K , instead of the magnetic lock.how do i connect the relay?pin 1 and 16?and from the power supply, there is 4 wire , 1 for 5 v , 1 for 12v.the two gnd wire should be connected together?
amol_shah
Full Member level 3
Nasik
hey plz post the datasheet or pin diagram of the relay
    devilmp4
amol_shah
Full Member level 3
Nasik
check page 7 of the data sheet frm which you will know the pin config (schematic)
Its a DPDT relay (Double Pole Double Throw)
Pin 1 and 16 is the relay coil,
pin no 8 is Common and 4 & 6 is its NC and NO respectively
and pin no 9 is Common and 13 & 11 is its NC and NO respectively
post the circuit that you have used
    devilmp4
devilmp4
hey.. 8051 give a 3.3 volt.if i use direct power of 3.3 volt from the power supply , it can work.but when i use 8051 to give a high, it doesnt work.the circuit is working properly, i think the main part is on the 8051 part.
amol_shah
Full Member level 3
Nasik
which port pin are you using? whats the value of the external pull up resistor
P0 does not have internal Pull up resistor so when you make any pin of P0 high it will be floating, so you will require external pull up resistor
P1, P2, P3 has internal 10k pull up so when you make any pin high the current will flow through the 10K resistor so if you require high current you will require external pull up resistor
    devilmp4
devilmp4
haha. thanks for reply.i manage to solve the problem already.thanks anyway :) . by the way, i nid 12 v. i have to change the value of the resistor and the transistor right?
amol_shah
Full Member level 3
Nasik
how did u solve it? what changes did u make?
u require 12v for the relay so no need to change the transistor u can use BC 547 u may have to change the value of the resistor since you are using 3.3v as Vcc
    devilmp4
devilmp4
erm , for 8051 , the pin must be change to push - pull port so that when u give a 1 , it will output 3.3v and when u give a 0 , it will output 0 volt.
