Help me build a LAN cable tester
permute
Advanced Member level 3
lan cable tester
i suspect the PHY will be a crucial component here.
Unfortunantly, not much is known about these features that are built into some PHYs. well, not unless your company has an NDA with the manufacturer.
pranam77
Advanced Member level 5
INDIA
lan cable tester
A project (with PIC microcontroller) of the same topic is published in "Elektor Electronics" July august 2010. Try to get a copy of the same. Any way the codes may be downloaded fron their site.
Cheers
Awarapunshee
Advanced Member level 1
Some Where In Heaven
Re: lan cable tester
sanjubluerock3 said:
hello i am looking to build a lan cable tester can any one plz share the info....
I sent the complete schematic with code. Kindly check ur PM
Regards
