dragonwell
Junior Member level 3
*warning* invalid cell view -- 0(unknown)
Greetings!
i am running $C5033 under RH9 & have the following 2 problems :
1) I can´t enter the text into varios fields, ie, cell view or instance name, even i entered, it will disappear when i try to type the next field. I heard that it could be fixed after changed the locale to en i/o cn, however, it seems doen´t help after i change it by using the kde locale tool.
pls help how to config the default to en manually.
2) the LVS doesn´t work even i try to run LVS for the mux2/Inv/nand2 extracted layout from ¨cell_design¨tutorial. but it works when i run this under ic5.0 .
below is the error message :
Running simulation in directory: "/home/xxx/myProjects/ic_design/cell_design/LVS".
Begin netlist: Jun 2 22:47:29 2004
view name list = ("auLvs" "extracted" "schematic")
stop name list = ("auLvs")
library name = "tutorial"
cell name = "mux2"
view name = "extracted"
globals lib = "basic"
Running Artist Flat Netlisting ...
*WARNING* invalid cell view -- 0(unknown)
global error:
Cannot find switch master cell for instance +13 in cellView (mux2 extracted) from viewlist 'auLvs extracted schematic ' in library 'tutorial'.
global error:
Cannot find switch master cell for instance +12 in cellView (mux2 extracted) from viewlist 'auLvs extracted schematic ' in library 'tutorial'.
global error:
Cannot find switch master cell for instance +11 in cellView (mux2 extracted) from viewlist 'auLvs extracted schematic ' in library 'tutorial'.
global error:
Cannot find switch master cell for instance +10 in cellView (mux2 extracted) from viewlist 'auLvs extracted schematic ' in library 'tutorial'.
global error:
Cannot find switch master cell for instance +9 in cellView (mux2 extracted) from viewlist 'auLvs extracted schematic ' in library 'tutorial'.
global error:
Cannot find switch master cell for instance +8 in cellView (mux2 extracted) from viewlist 'auLvs extracted schematic ' in library 'tutorial'.
global error:
Cannot find switch master cell for instance +7 in cellView (mux2 extracted) from viewlist 'auLvs extracted schematic ' in library 'tutorial'.
global error:
Cannot find switch master cell for instance +6 in cellView (mux2 extracted) from viewlist 'auLvs extracted schematic ' in library 'tutorial'.
global error:
Cannot find switch master cell for instance +5 in cellView (mux2 extracted) from viewlist 'auLvs extracted schematic ' in library 'tutorial'.
global error:
Cannot find switch master cell for instance +4 in cellView (mux2 extracted) from viewlist 'auLvs extracted schematic ' in library 'tutorial'.
global error:
Cannot find switch master cell for instance +3 in cellView (mux2 extracted) from viewlist 'auLvs extracted schematic ' in library 'tutorial'.
global error:
Cannot find switch master cell for instance +2 in cellView (mux2 extracted) from viewlist 'auLvs extracted schematic ' in library 'tutorial'.
global error:
Cannot find switch master cell for instance +1 in cellView (mux2 extracted) from viewlist 'auLvs extracted schematic ' in library 'tutorial'.
global error:
Cannot find switch master cell for instance +0 in cellView (mux2 extracted) from viewlist 'auLvs extracted schematic ' in library 'tutorial'.
si: Netlist did not complete successfully.
End netlist: Jun 2 22:47:29 2004
Comparison program did not complete.
some can help? thanks a lot !!!
Greetings!
cell name = "mux2"
global error:
global error:
global error:
global error:
global error:
global error:
global error:
global error:
global error:
global error:
global error:
global error:
global error:
global error:
