Help! ise core gen problem.
foredcn
Newbie level 6
I just installed ise6.3 with alliance keey. After installation, I do have "CORE generator" manu in the "\start\ise\accessaries\", But I can't open the core generator.
Running the coregen.bat gives "() system can't find the path specified".
How to fixed this? pls help me.
echo47
Advanced Member level 5
USA
Is only Coregen broken? Do other Xilinx tools work ok?
I'm not sure, but here are a few simple guesses:
1. Install both ISE CDs.
2. When you install ISE, enable the installation option that lets it update your path and environment variable.
3. If you run the Xilinx tools from the command line, restart the Command Prompt window after ISE installation, so the environment changes can take effect.
4. Maybe another program in your system has the same name as one of the ISE tools that coregen.bat is trying to run. You could try rearranging the items in your path variable.
