Help in Synthesis using DC compiler
renuvamsi
Hello ,
I have a question in synthesis process . This is the process i am doing ::
analyze -f verilog xyz.v
elaborate xyz
set_max_area 0
compile
report_timing
Point Incr Path
INS1/OUT_reg[0]/CP (FD1) 0.00 0.00 r
INS1/OUT_reg[0]/Q (FD1) 1.47 1.47 f
INS1/OUT[0] (SOP_width16_0) 0.00 1.47 f
OUT1[0] (out) 0.00 1.47 f
data arrival time 1.47
(Path is unconstrained)
thee is some data arrival time ...where does that come from ??????????
this is th report i am getting
then after setting timing constraints
create_clock CLK -period 40.1
without re-compiling , i am viewing the reports and i got the below report
Point Incr Path
clock (input port clock) (rise edge) 0.00 0.00
input external delay 0.00 0.00 f
B1[2] (in) 0.00 0.00 f
INS1/B[2] (SOP_width16_0) 0.00 0.00 f
INS1/r57/B[2] (SOP_width16_0_DW02_mult_0) 0.00 0.00 f
INS1/r57/U47/Z (IVP) 1.40 1.40 r
INS1/r57/U230/Z (NR2) 0.43 1.83 f
INS1/r57/U81/Z (AN2P) 0.91 2.74 f
INS1/r57/S2_2_2/CO (FA1A) 2.27 5.01 f
INS1/r57/S2_3_2/CO (FA1A) 2.27 7.29 f
INS1/r57/S2_4_2/CO (FA1A) 2.27 9.56 f
INS1/r57/S2_5_2/CO (FA1A) 2.27 11.84 f
INS1/r57/S2_6_2/CO (FA1A) 2.27 14.11 f
INS1/r57/S2_7_2/CO (FA1A) 2.27 16.38 f
INS1/r57/S2_8_2/CO (FA1A) 2.27 18.66 f
INS1/r57/S2_9_2/CO (FA1A) 2.27 20.93 f
INS1/r57/S2_10_2/CO (FA1A) 2.27 23.21 f
INS1/r57/S2_11_2/CO (FA1A) 2.27 25.48 f
INS1/r57/S2_12_2/CO (FA1A) 2.27 27.75 f
INS1/r57/S2_13_2/CO (FA1A) 2.27 30.03 f
INS1/r57/S2_14_2/CO (FA1A) 2.27 32.30 f
INS1/r57/S4_2/CO (FA1A) 2.34 34.64 f
INS1/r57/U6/Z (EO) 1.19 35.83 f
INS1/r57/FS_1/A[16] (SOP_width16_0_DW01_add_1) 0.00 35.83 f
INS1/r57/FS_1/U83/Z (NR2) 1.33 37.16 r
INS1/r57/FS_1/U4/Z (IVP) 0.19 37.35 f
INS1/r57/FS_1/U77/Z (AO6) 1.60 38.95 r
INS1/r57/FS_1/U76/Z (EN) 1.26 40.21 f
INS1/r57/FS_1/SUM[17] (SOP_width16_0_DW01_add_1) 0.00 40.21 f
INS1/r57/PRODUCT[19] (SOP_width16_0_DW02_mult_0) 0.00 40.21 f
INS1/add_22/B[19] (SOP_width16_0_DW01_add_0) 0.00 40.21 f
INS1/add_22/U1_19/CO (FA1A) 2.27 42.48 f
INS1/add_22/U1_20/CO (FA1A) 1.17 43.66 f
INS1/add_22/U1_21/CO (FA1A) 1.17 44.83 f
INS1/add_22/U1_22/CO (FA1A) 1.17 46.01 f
INS1/add_22/U1_23/CO (FA1A) 1.17 47.18 f
INS1/add_22/U1_24/CO (FA1A) 1.17 48.35 f
INS1/add_22/U1_25/CO (FA1A) 1.17 49.53 f
INS1/add_22/U1_26/CO (FA1A) 1.17 50.70 f
INS1/add_22/U1_27/CO (FA1A) 1.17 51.88 f
INS1/add_22/U1_28/CO (FA1A) 1.17 53.05 f
INS1/add_22/U1_29/CO (FA1A) 1.17 54.22 f
INS1/add_22/U1_30/CO (FA1A) 1.17 55.40 f
INS1/add_22/U1_31/Z (EO3P) 1.99 57.39 f
INS1/add_22/SUM[31] (SOP_width16_0_DW01_add_0) 0.00 57.39 f
INS1/U67/Z (AO2) 1.08 58.47 r
INS1/U66/Z (AO7) 0.45 58.92 f
INS1/OUT_reg[31]/D (FD1) 0.00 58.92 f
data arrival time 58.92
clock CLK (rise edge) 40.10 40.10
clock network delay (ideal) 0.00 40.10
INS1/OUT_reg[31]/CP (FD1) 0.00 40.10 r
library setup time -0.80 39.30
data required time 39.30
data arrival time -58.92
slack (VIOLATED) -19.62
now , i compiled it with the same time constraint
Point Incr Path
input external delay 0.00 0.00 r
A1[14] (in) 0.00 0.00 r
INS1/DP_OP_6J1_296_2454/U1140/Z (EN) 3.71 3.71 r
U5/Z (ND2) 1.67 5.37 f
INS1/DP_OP_6J1_296_2454/U881/Z (AO4) 1.70 7.08 r
INS1/DP_OP_6J1_296_2454/U792/S (HA1) 1.22 8.30 r
INS1/DP_OP_6J1_296_2454/U789/S (FA1A) 2.14 10.44 r
INS1/DP_OP_6J1_296_2454/U787/S (FA1A) 2.28 12.72 r
INS1/DP_OP_6J1_296_2454/U786/S (FA1A) 1.33 14.05 r
U309/Z (AN2P) 0.83 14.87 r
INS1/DP_OP_6J1_296_2454/U579/Z (MUX21L) 0.58 15.45 f
INS1/DP_OP_6J1_296_2454/U567/Z (MUX21L) 0.89 16.34 r
INS1/DP_OP_6J1_296_2454/U563/Z (MUX21L) 0.68 17.03 f
U368/Z (IVP) 0.69 17.71 r
INS1/DP_OP_6J1_296_2454/U553/Z (EN) 1.26 18.97 f
INS1/DP_OP_6J1_296_2454/U200/Z (NR2) 1.33 20.30 r
INS1/DP_OP_6J1_296_2454/U197/Z (AO7) 0.45 20.75 f
INS1/DP_OP_6J1_296_2454/U195/Z (AO6) 1.08 21.83 r
U374/Z (IV) 0.27 22.10 f
INS1/DP_OP_6J1_296_2454/U192/CO (FA1A) 1.17 23.27 f
INS1/DP_OP_6J1_296_2454/U191/CO (FA1A) 1.17 24.44 f
INS1/DP_OP_6J1_296_2454/U190/CO (FA1A) 1.17 25.62 f
INS1/DP_OP_6J1_296_2454/U189/CO (FA1A) 1.17 26.79 f
INS1/DP_OP_6J1_296_2454/U188/CO (FA1A) 1.17 27.97 f
INS1/DP_OP_6J1_296_2454/U187/CO (FA1A) 1.17 29.14 f
INS1/DP_OP_6J1_296_2454/U186/CO (FA1A) 1.17 30.31 f
INS1/DP_OP_6J1_296_2454/U185/CO (FA1A) 1.17 31.49 f
INS1/DP_OP_6J1_296_2454/U184/CO (FA1A) 1.17 32.66 f
INS1/DP_OP_6J1_296_2454/U183/CO (FA1A) 1.17 33.84 f
INS1/DP_OP_6J1_296_2454/U182/CO (FA1A) 1.17 35.01 f
INS1/DP_OP_6J1_296_2454/U181/CO (FA1A) 1.17 36.18 f
INS1/DP_OP_6J1_296_2454/U180/CO (FA1A) 1.11 37.29 f
INS1/DP_OP_6J1_296_2454/U178/Z (EO) 1.13 38.42 f
U597/Z (ND2) 0.64 39.05 r
INS1/OUT_reg[31]/CR (FDS2) 0.00 39.05 r
data arrival time 39.05
INS1/OUT_reg[31]/CP (FDS2) 0.00 40.10 r
library setup time -0.90 39.20
data required time 39.20
data arrival time -39.05
slack (MET) 0.15
I got the meaningful report
Why is it that before setting timing constraint , I am getting a meaningless report ....and also after setting timing constraint without recompiling , still non-sensible report
Then when i compiled it , I got a sensible report ....why is it happening ????
Can some one help me with this ?? mainly about the data arrival time
a few things ...
1) Without timing constraints loaded DC cannot see any valid timing paths. You will always get "Path is Unconstrained" for every path in your design.
2) Load your timing constraints before your initial compile. If not you will get lots of failing paths as in your 2nd report. Again, if DC cannot see valid timing paths, it cannot optimized them, so it's almost guaranteed they will fail.
3) You showed 3 different paths at the 3 stages. Sometimes you may want to see whats happening to the same path. Do this by ...
report_timing -from <start_point> -to <endpoint>
ex.
report_timing -from B1[2] -to INS1/OUT_reg[31]/D
4) Good constraints are the most important thing for good synthesis results. Do some checks to be sure you have good coverage on your design.
Be sure all your flops are getting clocked (I think its check_design -no_clock). You can also check the other errors/warnings in check_design.
