[SOLVED] Help in reset the controller ATmega32
shahbaz.ele
Advanced Member level 1
Islamabad, Pakistan
Dear all I want to reset my controller in software.
because of some problems in my circuit.
how to do it.
I am using Winavr software
ATmega32 controller
have the watchdog turned off, when you want to do a reset turn on the watchdog and let it reset the microcontroller.
It doesn't matter if you are already using it in your project or not, use it just for resets, I don't understand the problem.
The other solution would be an external circuit triggered by the mcu in order to reset it using the reset pin.
I want to restart my program once intrrupt is generated and executed. then the program should start from start of main.
A reset and the start of main are different things, if you just want to jump to the start of main then you can use goto to jump in a label positioned in the start of main but this will not reset the mcu.
Note that you shouldn't use goto inside the interrupt, instead you should just set a flag variable and then detect the value it has in the while loop (inside main) and jump to the position you want.
