The coil contacts will energize the relay. And other six are grouped in 3 + 3.
2 of them on each side will be short normally and will open and shorted to the other one when energized.
Your picture is too small i cant read. but the left most pins are the coil pins.
next to it, the 2nd pin on each side is a common which will be short to the last or 2nd last normally.
check with meter.
---------- Post added at 19:39 ---------- Previous post was at 19:37 ----------
check with meter.
