help in mentor pcb tools (dxdesigner and expedition)
moustafaali
Member level 2
cairo,egypt
i'm started to work in mentor pcb tools from few days and i need more help in this field
i need useful links to dowload useful documentations and links to special forums i this field
any one can help me ?
thanks
moustafa
Hi, I'm working with WG and prefer DxDesigner-Expedition Flow!
all what U need
(INSTALL PATH)\ MentorGraphics\2005EXP\docs\pdfdocs\
thank you for your help
i find after finishing the schematic of certain design that the are no errors in the step of schematic check and after make packaging find alot of warning and no errors and when i launch the schematic to the expedition pcb there are message appeared said that cannot make back annotation and after this i complete the forward anntation and the layout not appeared in the window instead of the constraints which i changed it in dxdesigner appeared in the expedition
this is the problem if you or any one know the solution please help
Hi, if you send me your project maybe I can help you.
