mshh
Full Member level 6
I am trying to do constant power load, the transistor switches the current source which ranges from 0-30v and the load is 6.8R50w, there is opamp power vcc 12v used to control the BJT base emitter voltage. Could you recommend BJT transistor that could draw 4-5amp with small heatsink
