help in Avr program!!
karan123
Member level 3
I have made ISP programmer given at.
PonyProg2000 - Download page.
I am successfully blink LED with that programmer but it takes
but i takes 1 to 2 min for loading hex file.
is it very slow??
now i have written program for serial communication and lcd as attachments
but they are not working
i am checking on hardware
my hardware in ok because ATmega8515 is pin to pin compatible with 8051
both things are working with 8051 code.
any other setting or mistake in program.
i m using AVR studio and WINAVR GCC.
Also ,
What are fuse bits? how to configure that and when to configure that?? (in AVR studio).
Karan
  • programs.rar
pony prog is good software. check ur crystal. be cautious in using fuse bits of avr. it is the main complicated part of avr. read datasheets as many times as possible. check tis post if u wrongly programed avr https://www.edaboard.com/threads/131804/
Better go for usb based programmer, usbasp is one of the option.
Fusebits are used to set the options like oscillator, brownout, bootloader, lockbits, etc.
Be careful with fusebits or else you will need a parallel programmer to reset it
Thanks...
you have checked my attachment Program?
by karan
Check the fuse bits for oscilator ,in the program is not prezent do it like this:#define F_CPU 8000000UL // 8 MHz or else
then seee this page : AVR Fuse Calculator for ATmega8
and correct fuse bits.For slow programming with Pony -do you use calibration button from control panel?
Thanks
I have changed my X'TAL .Now programmer is fine.
After Writen :
Serial communication working fine.
But LCD program still not running.
How to use calculator to calculate proper fuse settings..
Like i am using ATmega8515 with 8 MHz Crystal OSC.?
Karan
Post all code please for LCD,libraly from where?4 bits or 8 bit use for comunication wiht LCD?
Crystal i not a problem.Shematics for circut ,pins and ports?
Thanks for Reply..
Here is code.
I am using LCD 16 x 2 in 8 Bit mode..
But my Serial Communication working fine.
karan
  • lcd1.rar
Thanks for Reply..
Here is code.
karan
I think that you are using 4 bit mode.I will test on my board ,but with atmega8535 and in BASCOM AVR ,and post a .hex file so you can try .
ports: Pin , Rs = Portb.0 , E = Portb.2 , Db4 = Portb.4 , Db5 = Portb.5 , Db6 = Portb.6 , Db7 = Portb.7
hex:
:100000000C942A001895000018950000189500001F
:10001000189500001895000018950000189500002C
:10002000189500001895000018950000189500001C
:10003000189500001895000018950000189500000C
:1000400018950000189500001895000018950000FC
:10005000189500008FE58DBFC0E4E8E34E2E84E0E4
:100060008EBFD4E0F4E05F2EEEEFF3E0A0E6B0E068
:10007000A89584B7082E877F84BF88E1992781BD22
:1000800091BD88278D933197E9F70E947700662408
:100090000E946900E1E0F0E00E946E00EAE0F2E018
:1000A0000E9460000E946700ECE1F2E00E946000A4
:1000B000E1E0F0E00E946E000C944800F894FFCF5D
:1000C0000E940101802D11F05AD0FACF089580ECE2
:1000D0005CC081E05AD008D080E857C088EE93E039
:1000E00081D03197D9F7089583E099277BC08AEFB3
:1000F00090E00E94F200BF9ABE9ABD9ABC9ABA9A4A
:10010000B89AC09885E090E00E94F200C298C79823
:10011000C698C59AC49AC29AEF93FF93E4ECF0E0B4
:100120000E94E600FF91EF91C29859D0C29AEF93D6
:10013000FF93E4ECF0E00E94E600FF91EF91C2989B
:100140004ED0C29AEF93FF93E4ECF0E00E94E600F9
:10015000FF91EF91C29843D0C498C29AEF93FF9356
:10016000E4ECF0E00E94E600FF91EF91C29837D0F6
:1001700088E20BD08EE009D086E007D00895C09ABF
:10018000829505D004D02BD00895C098F9CF8595DD
:1001900010F4C49A01C0C498859510F4C59A01C0A2
:1001A000C598859510F4C69A01C0C698859510F437
:1001B000C79A01C0C798C29AEF93FF93E4ECF0E0AE
:1001C0000E94E600FF91EF91C29808953197F1F7F0
:1001D0000895689462F80895E89462F8089581E0BB
:1001E00090E000C0EF93FF93EE27E82BE92B31F06E
:1001F000E0EDF7E03197F1F70197D1F7FF91EF913B
:100200000895C895319600200895A0C2BBB46170CE
:1002100063BAB820BE6F70BF61BB00002020BE6F04
:0A02200020706FB26FBFB8BA610022
:00000001FF
The LCD is in 4 bit mode.RW to -/gnd/.if is not working chek cables or LCD
If you are using pony prog for programming software ,you can not program fuse bits automaticly.
If u used PonyProg to programme your chip, the first important thing u have to think about is the Fuse bit. U need to know your fuse bit configuration. For example CKSEL0 bit, CKSEL1 bit...It decide frequency in which your chip is actived. If u make mistake with your fuse bit, your chip may not work.
By the way, 1 or 2 minutes is not problem with PonyProg. Your chip can work well if the programme inform sucessfull.
In this picture, u need to discover:
OK..
But my Serial Communication code working fine..
After Writen :
Why not LCD Program?? As previous Attachment.
After Reading from From Datasheet , I have first program the fuse bits from as .jpeg to loading .hex file?
is it the correct method for that?
hanks
karan
It is wrong. Becuase in PonyProg, let u see the notice below: Check items means programmed (bit=0). So if u want the chip work with external crystal, u have to config with all CKSEL uncheck. By defautl, the chip work with 1MHz internal.
Regards,
My Code is working fine in Simulator.
but not on hardware.
I am using AVR stdio with AVR GCC compiler with ponypro programming software?
may be small problem.
any experience person in avr plz. reply..
what left?.. for running code in hardware
karan
  • lcd1.rar
CKSEL 1111 SUT 11 to work with extal crystal or resonator High Freq.
See here:
Or program "AT90S4414/8515 compatibility mode" fuse
Simulation & real hardware differ in timings. Increase/ insert timing after sending first command (0x38) and following commands.
Nandhu
@nandhu0
I have changed Delay but no success!!!
The code is present in the first att. but ,I think that some wrong connection in the project or loss of signal,or some port of the MCU is damaged.Test the ports with LED and resistor wit simple on/off code.
