Feb 1, 2004 #1 M marsvoltaire Junior Member level 2 Joined Jan 28, 2004 Messages 20 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 144 16f877a serial port programmer Anyone knows schematic for 16f877 programmer using serial port. thanx
Feb 1, 2004 #2 SphinX Advanced Member level 3 Joined Jan 25, 2002 Messages 822 Helped 58 Reputation 116 Reaction score 29 Trophy points 1,308 Location EGYPT Activity points 7,045 16f877 programmer with serial port Hi, Try TE-20 It's JDM based. https://www.volny.cz/eremy/progser/te-20_sex.zip Use Ic-PROG with it. I re-edit the pcb to remove the smartcard connector because i don't need it. But i forgot where i saved it after the modification SphinX
