steven_jun
Newbie level 5
The circuit at the top serves as a bias voltage generator for the actual LNA:
The 4 BJTs (bipolar junction transistors) Q1x & Q2x together with the NMOS NM0 constitute a balanced differential amplifier with a 1:1 (R14:R13) negative feedback, so regenerating a buffered temperature-dependent Vbe (created at the connection between I2 & Q0). The voltage level at the drain of NM0 will be 2*Vbe, at the junction of R14/R13 = input of the AMP this will be 1*Vbe. If the proper LNA BJT DZ17 is thermally coupled to the bias generator BJTs, this guarantees a largely temperature-independent collector current of DZ17 .
Seems you don't understand the temperature-dependent Vbe effect on the drain current stabilizing effect of a BJT in case of effective thermal coupling.... there is no independent temperature current generated.
No and yes: BJT current mirrors need to have the same Vbe potential, i.e. have both their emitters and bases in common, which obviously is not the case in this circuit. It's a buffered current mirror, however:why the voltage at the drain of NM0 is 2Vbe? I think the current is decided by I0, Q0 and DZ17 are current mirror.
Right: With a temperature-independent current I2, a temperature-dependent Vbe(Q0) is generated. Neglecting DZ17's input resistance, the buffered voltage at DZ17's base is Vbe(DZ17) = (1+(R14/RZ18))*Vbe(Q0)*RZ18/(R14+RZ18) = Vbe(Q0) , so you could consider DZ17 as a "buffered current mirror transistor" of Q0. As DZ17 receives the same (but buffered) temperature-dependent Vbe as that one generated by Q0, it will reproduce the same temperature behavior as I2 -- good thermal coupling between the 2 BJTs implied.could you say some more about the independent current or provide some reference? does it generated by NM0 and the Vbe?
R13=8*R R14=2R, R0=4R , i dont know how to determine the collector current of QZ17,because i dont know the drain voltage of the nmos NM0
Ok.R13=2*R0
No: IB(Q16)≈IB(Q18) ; their collector and base currents ain't necessarily equal, as their collector voltages ain't necessarily equal.IB(Q16)=IB(Q18)=0.5*I0/(1+beta(Q16)
?? How do you get this equation?VBE(DZ17)=VBE(Q0)+0.5*IB(Q16)*R13.
Yes, it is. But not according to your above equations. It's much easier: Ic(DZ17) ≈ Ic(Q0) ≈ I2 , if both BJTs are of equal size and thermally well coupled, see my contribution above. The ratio of R13/R0 shouldn't change a lot.... then the collector current of Q(DZ17) is determinated. do you think ?
