HELP:How to transmit data with ZIGBEE using visual studio c++
Jyn Flores
Newbie level 1
Two xbee series 2:
XBEE 1-connected to a pc(which transmits data to my other xbee)
XBEE 2-receives data;connected to a LCD.
Question:
1.) Are there any libraries in xbee?
Thanks in advance. Newbie here.
Two xbee series 2:
Question:
you could connect the XBEE to the PC serial port and then communicate with the device using serial IO functions, e.g. in C, C++, C#, VB, java etc
Agreed the USB Zigbee module should mount as a standard COM port. You should then be able to talk to it with the SerialPort class.
Rob.
