Help: How to program power window when using PIC18F4455?
sarah.sanchez
Junior Member level 2
How do you program the microcontroller (PIC18F4455) in MikroC to make the power window work? Thank you. Would greatly appreciate help on programming because I'm relatively new to this.
Regards,
Sarah
sarah.sanchez
A power window is like a servo motor which can be raised and lowered by depressing a button or switch. In our case, we will be automating it so that it will be time based and will be following the sun.
