if i am getting you right you want to use external hard drive with usb interface.
you can mount the external drive same as you mount your internal drive instead of using 'hda' you must use 'sda' in your mount command eg:
to mount internal drive
mount /dev/hda1 /mnt/cdrive
to mount external drive
mount /dev/sdaX <mount point>
where X is partition number you might use in case of internal drive
Re: [help] How to mount mobile hard disk (usb device) on lin
1,<fdisk -l> to show the devices recognized by the linux .
2,then choose the exact one to be mounted :
<mount /dev/(to be mounted driver) /mnt/(mount point)>
