[help] How to get track impedance with PowerPCB
manitooo
Full Member level 2
I can see in the detail windows taht impedance could be display but don't know which information should I check or give to PowerPCB to get this information...
THX, manitooo
Impedance depends on the dielectric material, dielectric thickness of prepreg, track width, copper thickness,
details can be given in the layer stack-up table to define the impedance values
amjad tell right. For example with Hyp*er*lynx it's possible
to calculate the impedance of layers stackup ant other.
In Power*PCB if you have advanced rules and high speed options.
Yuo can select: Set*up - Des*ign Rul*es - Ne*ts - then select a net
and select Hi*Speed Rules, now you can set a range of impedance.
But remeber before you can set the correct layers thickness.
When you start Verify Design the system check if the range of a track
is ok.
Hope this help, Skywalker.
does anybody have some examples value for a home made single side and double side board ?
In powerPWB, it is also possible to get this information, but I have seen it when creating a mixed/plane layer...., when I return to the non mixed/plane layer, I lost this information...
are they linked to an available mixed/plane layer in the design ?
manitooo,
i don't understand your question.
What value in a single or double side board ?
Skywalker.
I mean value of the thinckness of the dielectric, the copper and some mechanical data of a PCB...
In the menu :
setup\layer definition\thickness, you can put the different layer thickness constants...
I was wondering about the good value to put into the box when you make home made PCB either in single side copper (top or bottom) or double side copper (top and bottom)
thx
