According to the image,
I want to generate the crc_scope according to the soc,eop and val.
As we know,we normally get the falling edge by delaying signals two cycles and then to get the last two-byte pulse scope signal,just as shown in the image below. but how to get the signal for the image above(crc_scope in red)??
Ignore VAL. Delay SOC (maybe use a shift register) to produce the first Crc_scope pulse. OR it with EOP to produce the second Crc_scope pulse. The result will look like your picture.
If you want Crc_scope to respond to changes in the other signals, then you need to describe your problem better.
