[help] How to dump FSDB file in Modelsim?
mic_huhu
Member level 3
Hi,all
there are so many arguments about how to dump fsdb file in modelsim. this make me fuzzy,
who can clear up it.
BTW: This is can be done in linux?
xworld2008
Full Member level 4
You should have debussy first , and at debussy you will find PLI, and you should read debussy help to compiler the PLI with you system. or you should set path of debussy PLI . How to use pli you need to read modulsim help.
mic_huhu
Member level 3
Thks ,xworld2008, I have fix the problem.
roger
Full Member level 3
Are you using Verilog or VHDL? The way to gen fsdb of them are different
