[Help] How to connect PA with LNA to share the same antenna!
guilinwxb
Junior Member level 1
Hi, everyone. I am design a 2.4GHz CMOS transceiver IC. But I don't know how to connect PA with LNA to share the same antenna, and has TX/RX switch. The PA core and LNA core are depicted as the figure below. Anybody can help me? Thanks!
guilinwxb
vfone
Advanced Member level 5
Re: [Help] How to connect PA with LNA to share the same ante
You need a balun on each side (RX and TX), and the outputs of the baluns routed to the SPDT T/R switch.
kspalla
Hyderabad, Andhra Pradesh, India
use two spdt switches.
let say +ant, -ant is the common signal on state 1of swich it connects +ant to +PA and -ant to -PA on the switch toggle +ant to +LNA and -ANt to -LNA
You need tWO SPDT switches to have the required isolation.
Added after 36 seconds:
I mean DPDT should be OK
DDavid
Full Member level 5
Hi
You can design the switch with 2 diodes!!
of course you must consider the isolation.
Also you can use with cilculator and isolator!!!
David
guilinwxb
Thans everybody, after reference some IEEE paper, I decide to use this switch such as below and use a match network off chip. Tune the LC network to let the LNA's noise as low as possable and the output power of the PA is as large as possable. But I feel it's difficult to tune. Do you have any suggestion?
Thanks
guilinwxb
