[Help] Hi-tech PIC C Beginner need help on i/o
johncsl82
hi.....
I already search the entrie post for some tutorial dealing with I/O..... but it seems I still have some problem dealing and understanding with the code..... it quite confusing me....
Anyway can you guys to help me out to clear thing up?
ok my questions are:
1. what is the function of "@" and how to utilize it? if A @ 0x03, means A = 0x03 or A address is fixed as 0x03 or else?
2.how do we receive an input coming from a pin?
3.how do we send an ouput to a pin?
4.how to detect incoming data? using infinte loop?
5.how to send or receive a group of binary (0111 0001)? does frequency or time matter?
6.how do we check the microcontroller frequency and modify it?
7.how do we check the microcontroller "time" and modify it?
8.how do declare our own interrupt, plus how to retrieve list of available intterupt in the microcontroller?
9.can we declare our own register?btw, i find register like RCREG, RCIF and etc etc how do we utilize it?
10.if send an ascii character like 'A' do we have to convert to hex then to binary and send it?
11.how do we make the program go into sleep or wait mode?
12.how do we utilize the option pin function, for example PIN PORT C 3 has 3 function, which are RC3/SCK/SCL... plus other available dunction on the microcontroller?
13.PORTB = 0x02 //set 4 bit mode? or it means PORTB1 = 1?
:confused:
Thanks
:eek:
i recommend tat u go thru the manual of pic c and to understand the specific functions u hav to understand tat pic's various ragisters for tat u hav to hav a very good look at the pic's data sheet, i believe u will find the answers there, becaz i had the same sort of problem wen i started hitech pic c, if u hav still problems plz dont hesitate to ask,,,
rwgards
    johncsl82
This might Help you out. Did a search here and did not find it.
Good Luck
Enigma460
    johncsl82
Hello
If you have bought the PICC compiler, then you can have a direct customer support form Hi-Tech themselves, I think they will not hesitate to answer any question, even if its as simple as asking them, what is the differnece between PIC16F84 and PIC16F84A :)
My self I don't use any Hi-Tech product, but a friend told me they have excellent customer support.
Regards
    johncsl82
the address of a is 0x03...
ex
char value
value = PB5;
char value
if ( value == 1)
PB5 = 1;
else
PB5 = 0;
or an interrupt
or
while ( PB5 == 1 ){
what do you mean uart?
if the mcu has the ability to change the frequency
form the OSCCON
NO
value = 'a';
PORTB = 0x02 equal to PORTB = 2 equal to PORTB = 0b00000010;
    johncsl82
xxtigerxx... thank for reply
I mean software implementation rather than hardware(UART).......
let say i got a binary '0b0111 0001', if we send it to port a pin 0 (RA0)
we just put like RA0 = 0b0111 0001?
how about receving it in a group?
"time" -> prescaler or TMR0 (8-bit timer/counter)
Thanks
see in files .h of hi-tech c or MPLaB C
    johncsl82
hai
10) registers like rereg and rcif are special function registers
this registers will be used to configure and control theat particular peripheral
Added after 4 minutes:
by executing the instruction sleep wecan go to the sleep mode
in this pins the peripehral functions are multiplexed so at a time we can use as a one
ya it is correct
there is no problem to study
you just go through the material more than one time to understand better
still you are not able to understand then do one more time reading
which will help you definitely then concepts you won't forget at any time
best of luck
    johncsl82
i having a little problem here:
void main()
	unsigned char rb, sb;
	TRISA0 = 1;
	TRISB1 = 0;
	TRISB2 = 1;
	TRISB6 = 0;
	TRISB7 = 0;
	RB6 = 0;
	RB7 = 0;
	sb = 0x0f;
	rb = 0;
	for(;;)
		if(RA0 == 1)
			//send8Bits(RB1, 0x0f);
			RB1 = sb;
			//rb = RB2;
		rb = RB2;
		//if(receive8Bits(RB2) == 0x0f)
		if(rb == sb)
			RB6 = 1;
			RB7 = 0;
		else
			RB6 = 0;
			RB7 = 1;
it seems that RB1 = sb; mean sending out 0b00001111 at a time, is not working..
but if I change sb = 1, it's working....
so does this mean i have to send bit by bit?
Thanks
Dear johncsl82
RB1 it is a bit and the bit 1 of port B
sb it is a char it have 8 bits
the compiler will put on RB1 the bit 0 of sb
you could do something like that to take out the bits
the simbol (>>n) makes a rotation to rigth of n bits
RB1 = sb // this put bit 0 out
wait some time
RB1 = sb >> 1; // this will put bit 1
wait some time
RB1 = sb >> 2; // this will put bit 2
if you catch the idea you could use a for stament
unsigned char ucN;
unsigned char ucTime;
for(ucN=0; ucN<=7; ucN++)
RB1 = sb >> ucN;
// delay to see it in pin
ucTime = 255;
while(ucTime--){};
hope this help you, other way it is using timer0 to put out bit in a sharp time
    johncsl82
hea
unsigned char ucN;
RB1 = sb >> ucN;
ucTime = 255;
while(ucTime--){};
and
wait some time
wait some time
so delays r required
test some basic mode s first for all the timers
if u have a osscilosope and observe then it will be great
in hardware
hope this help you,
    johncsl82
ans:
@ may sometimes as label
@ pointing address
but there are rules in assembly language that prohibits it.
@ 3:
instead
label3:
if conditions
goto label3
ans:
a low or high input level
a digital signals
0 volts = 0 = off
5 volts= 1 = on;a floating signal
for a data port
pb.0=0x02 // first port - first bit send an output 0010
pb.1=0x03
ans: compare variable,parameterss
do
var ++ // increment or decrement
if(var -compare-value) // detector for control
} while(Var-value) // control -infinite or not
ans: somehow yes if you are grouping it into a bits ,byte, word - or equivalent data type but in syncronizations times matter most and frequency as well
ans:
.. first you have to read the crystal oscilator or its resonator
that produce the pulse of the device-Microcontroller
... need to know also the input clok.. then if you desired designing
clock variability device such as 555 or equivalent family
the formula-RC chargingConstant
F = 1/T
T=RC
ans:
need to read the data sheet of whatever Microcontroller you want and find out
all the interrupt you are able to map inside its ROm -Interrupt architecture
or a compiler itself able to read the I/O Mapping
[b]ans:
take note that in I/O map of its microcontroller architecture
the next addresses are reserved for a user temporary storage or say memory
ex
0000 - stack
01F0 - instruction
0FFF - Reserved temporary
FFFF -----
ans:
take note all dispaly are characters
' a',bc,d ...'1','3'
in digital system it has an equivalent aschi code in hex,
which hex also has an equivalent bits
ex
'a' = 40h = 01010>> this what you are processing inside the machine
ans:you use loop and its equivalent interrupt
you are refrerring to a declarations a hex value assigned to a port
say 2h= 0010
:confused:
maybe not this time anymore
wish i could help...Thanks
Cyrix-Cracker
I recommend not to use "@" instead use BANK1,BANK2... In most cases you cant follow the adress.
hi guyes
could you please give me alink or upload abook about the pic microcontrolleres
thanks .....
Ouch I don't have the necessary points to download :(
Can a kind soul please donate some points to download this one? Thanks
