help for triac drivers
deepakchikane
Full Member level 3
Full Member level 3
Mumbai, Maharashtra, India, India
Dear all..
do i know how to drive the moc..
i am attaching ckt here...
bt something is burning from ac side..
Dear all..
this is application note of fairchild... can anyone help me out to chose the o/p resistors..??
looking forward to hearing you sooon
  • MOC 3083 APPLICATION NOTE.pdf
Figure 8 and Figure 9 are correct in the data sheet and the values are correct. If something is burning you have it wired wrongly or the triac is faulty. The most common problem I have come across is the triac main terminals being reversed.
What are you driving the MOC with? Please show how you have it connected at the moment.
Brian.
If it is reversed the chances are the resistors around the MOC will be damaged and the triac will conduct all the time. The MOC itself would probably survive because the triac would by-pass most of the current around it.
Brian.
