HELP for Fujitsu thermal printer FTP-628MCL103#70
scd
My Fujitsu thermal printer FTP-628MCL103#70 is not printing..
Any views?
Whether test print is functioning. then check fuse, whether it is blown out
then check paper out detection sensor is working.
---------- Post added at 23:08 ---------- Previous post was at 23:05 ----------
scd,
Your question doesnot give us any details.
Are you trying to interface it to some controller?
Is your hardware tested
Are you having issues with software
Have you tested each thermal printer parts
Were you able to run only motor first
Are you following correct timing sequence
Are you providing appropriate power input
Weather it is battery powered.
Lots of questions like this. No person on any forum will be able to help you unless you ask proper questions.
