Help for common mode wave
apriori
Newbie level 2
Hi Sirs,
I have a question need for your help.
What is the common mode wave or common mode current?
Does it different with diffierential mode?
Thanks.
dingjingfeng
Full Member level 4
common mode signal have the same phase and amplitude(usually even harmonics)
differential signal which have 180 degree phase shift but have the same amplitude.(usually odd harmonics)
kishorekumar_ms
Member level 5
common mode wave is one in which all mode fields resonate at same frequency.... these generate linear polarization.
pablohoney
Junior Member level 1
To define common-mode or differential for something, it must have two inputs. If the two inputs are different (it may be voltage or current), you will have a differential output. If the inputs are the same, you will get a common-mode output.
Hope it works, good luck
