Help for AMS Simulation
DenisMark
Full Member level 6
Russia
ams simulator tutorial
I turn in Cadence AMS Designer and have problem.
I have IC5.033 and LDV5.0, AMS example from Cadence help (SAR_A2D) and tutorial for AMS simulation from Cadence AMS Environment help.
I follow this tutorial and at the elaboration stage have error:
ncelab: 05.00-p001: (c) Copyright 1995-2003 Cadence Design Systems, Inc.
ncelab: *E,NOUNIT: Unable to find a unit named 'mixedsignal' in the libraries.
ncelab: Memory Usage - 8.4M program + 1.6M data = 10.0M total
ncelab: CPU Usage - 0.1s system + 0.0s user = 0.1s total (0.5s, 12.0% cpu)
What is going on? Who can help me?
And second when I run ./runBehavioral example script I have error that "compile" and "compilevhdl" is not found. Where is it placed?
cadence ams tutorial
please read the README.
"The Cadence-provided libraries must be compiled before use. Usually
the person who installs the Cadence software also compiles the
libraries so you can run the tutorial immediately. ...
The person who installed the software can compile the VHDL library
by changing directories into the $AMSHOME directory and running the
following command.
./tools/inca/files/install/ncvhdl.ins
Similarly, the library of connection modules can be compiled with
the following command, issued from the same location.
./tools/affirma_ams/etc/install/amsConnectLibCompile"
