HELP EAGLE PCB WITH USING BUS
zia.roghani
Member level 1
HELP EAGLE PCB
I M USING BUS IM MY DESIGN.
THERE IS ERROR " ONLY INPUT PIN ON . CH52"
WHERE CH52 IS ONE OF THE SIGNAL IN THE BUS.
WHERE CH52 IS SIGNAL GOIMG FROM BUFFER TO MUX.
REGARDS.
Re: HELP EAGLE PCB
So CH52 is connected to the input of a MUX and it's connected to the input of a buffer. Please check if that's really what you want.
Also check if the wire is connected to both pins (move the symbol, the wire must be attached to it).
If you find that everything's fine, check the direction of these pins in the corresponding libraries.
