Help! Difference between Walsh and Hadamard Codes?
Communications_Engineer
Advanced Member level 3
Sindh, Pakistan
Hello I hope you're all doing fine; the member of edaboard
Now, my question is, what is the difference between Walsh codes and Hadamard codes and the so-called Walsh-Hadamard codes, tehy all look the same to me.
Can some one explain?
hi Communications_Engineer
Dr. Mahmood which is a member in ofdmandmatlab know the answer. as his PhD was specialised on this problem.
Thanks
