Help : Converting 8 bit to 16 bit
Maverickmax
Advanced Member level 1
signed 8 bits
Hi
I am struggling to understand why negative 8 bit convert to 16 bit ? What about positive?
What is the benefit?
if (data[i]&0x0080)
         data[i] += 0xFF00; // convert to negative 16-bit
else
         data[i] = data[i];
end
The most significant bit of a signed number is the minus bit. Without the adjustment to a 16 bit ('+= 0xFF00') negative an 8 bit negative would be still be a positive number in signed 16 bit.
Because we only want to convert a range limited subset, we need to adjust the negative value.
In a signed 8 bit number we go from -128 (0x80) through -1 (0xFF) then 0 to +127 (0x7F).
In a signed 16 bit we go from -32768 (0x8000) through -128 (0xFF80) to -1 (0xFFFF) then 0 through +127 (0x007F) to 32767 (0x7FFF).
As you can see, the positive side need no adjustment, but the negative needs to be within -128 from zero (0xFF80) for the conversion to work.
Try googling 'twos complement' if you need more information on how this works
I can’t remember a situation where I needed to do this ”conversion” (called sign extension) myself! Why would you?
Use casting [with care] instead and the compiler will take care of this for you and will do that more efficiently.
For instance:
signed char signed8 = -7;
int signed16 = (int)signed8;
will correctly give signed16 = -7
If your data comes form a stream, read it in a signed 8-bit variable first and cast it to a signed 16-bit. This can also be done in a step, like this:
int signed16 = (int)((signed char)data[i]);
Doing this you'll never need to hear about 2's complement again!
Arthur
