help-connecting a dipole to FM radio
deepak007
Member level 5
japanese fm dipole antenna
hello
i am new to the transmission lines. could any one tell me how i can connect a dipole antenna to the FM radio.i mean, i want to put the antenna on the terrace. which cable(75ohm or 50ohm) should i use.
my reciever is an old NATIONAL PANASONIC TAPE RECORDER, with AM/FM/SW1/SW2 bands.it has a whip.but, it has a provision for dipole antenna.
what is the maximum length of the cable i can use. will the cable have any effect on the working of the radio?please guide me.
fsmyth
Member level 4
Most early sets used a balanced 300 ohm interface.
Twin lead flat cable is used to the antenna.
If there is a coaxial jack, it is probably 75 or 90 ohm.
deepak007
Member level 5
i have a small doubt.if i connect the antenna to the receiver using a 300ohm ribbon cable,won't the cable act as an antenna itself. will there be any signal loss?
gprabha
Newbie
New Delhi
If at all you need an antenna, simply extend your double whip(indoor colour/BW Tv antennas) to terrace as dipole, connect it through cable TV coaxial cable!. If you are in dry area, having a shunting choke across antenna would save your costly receiver from static .
