surfing
Junior Member level 3
Hi everyone,
My buyer want to help to build the following jig,which requirement listed as below.
Could somebody give me some suggestion?
Thanks very much
test rig built to do a particular experiment.
The details of the design are:
Two female COAX inputs
One female COAX output
Both inputs should have adjustable gain so that the incoming signals can be
reduced during tests.
The frequency response should be at least within the UHF frequency band.
The two inputs should be reverse wired from each other. That means that
INPUT-1 = +/- and INPUT-2 = -/+
So if I feed two identical signals in the input, and the gain is set to be
the same on both inputs, the output should be 0 signal.
Thanks very much
