help...broadband connection
DavidNelly
Member level 5
Dear colleagues.
My broadband link connection takes times to connect when my power system fail and start again. At first, it takes time about 5 minutes. But now, longer than it.
I don't know where is the problem.
Thanks
modem type ? operating system ? distance ? ISP (maybe DSLAM known) ?
Kindly, if the DSL on you modem is working that is mean your your line is working probrly frfom ISP sit to solve this problem
1- check the MTU configuration on your modem
2-check your NIC, my be causes this problem, or the interface card even you work via wireless
3-check Tepm. File some time causes many problems
after that if you didn't any problems from this componant you should contact with ISP to change the connection for you , sometimes the WAN connection PPPOA,PPPOE ot compatable with the parameter of line .
Thank you M Shaker,
I've changed the modem and now it is ok. Thank you for your hinks.
