I need help with my project.. I'm designing a safe deposit box with ATmega16.. And it can store the data containing the time when the box is opened (using 24C256)..
And later the data can be read by a computer (or PDA).. and I want the communication using USB..
So my question is how do you communicate ATmega-computer using USB?
I was told that my device should be USB client.. Can anyone help since I'm still new at electronics..
I think you could use the v-usb (formerly avr-usb) its very easy (if you work easily with avr-gcc) to setup an application like that. (there is an example ready to read and write the eeprom of an AVR by USB... it's also HID so you will not need even to install a driver on the computer!!!!) I think this is what you need before going under deep USB aaplications (using AVR USBs and so...)
