hillstream
Newbie level 1
I sim a 3 terminal diff L with 2008 ADS Momentum.
After loaded the inductor gds file into momentum, after change layer, set sim condtion. then rum sim.
But there a error out as:
Warning:
If the geometry contains lines that are within 1 degree of parallel they will be treated as parallel because the layout resolution is relatively coarse for this geometry. Plsease increase the layout reasolution if this causes problems.
Error:
MommSHmaker: internal error 11 -- segmentation violation.
I have set the VIAs as 3D as a topic question said, but error still out.
How to resolve it? Could anyone help me? Thanks!
Warning:
Error:
