Help:Adjust resolution (nunber of color and pixel) in RH72?
edaguy69
silicon land
How can you setting your montitor display in RH72: number of Clolor and resolution. The application I am running require high resolution and it complain that my setting is not true color. Thanks
linux
su root
run setup to change the display!
you run xf86config, or manually edit /etc/X11/XF86Config file
before starting X
