help about delete initial value in writing to a text in vhdl
raziyeh94
Junior Member level 1
hello.
please help me.I have a flip flop and I make it as a component. vhdl codes write output of flip flops.but vhdl codes write initial value of output of flip flop in first line of text .I dont want it writes initial value. I want write new value in first line of text.what do i do?
a part of my codes is here.
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
d(1)<= transport start after f_tchoise(min)+f_tchoise(calibration);
gen:for i in 1 to m generate
d(i+1)<=transport d(i) after f_tchoise(min);
ff1:FF port map(d(i),stop,q1(i));
q(i)<= q1(i);
end generate;
write1:process( stop)
variable check: line;
file outfile: TEXT open write_mode is "data\output4.txt";
begin
if (stop 'event and stop='1')   then
write ( check,q);
writeline (outfile, check);
end if;
end process;
I dont really understand your problem. The code is also not complete.
What is the problem?
You will output Q every time you get a rising edge on the stop signal.
output of flip flop (q) is written in a text file with rising edge of stop signal .but in text file the first line is initial value of q,for example(q=0).I dont want it write initial value of q.I want the new values of q become in first line of text.
Well then prevent the first write from happening using some enable signal or something (if enable = '1' then write = '1'..Set enable to '1' after q becomes '1').
