sevid
Member level 2
Hi,everybody,
when i use behavioral synthesis command "bc_check_design" on my behavioral code,ERROR:
Information:Checking for reset loop coding style will be performed on the reset loop.
Error:There must be a main(infinite) loop inside the reset loop,if you are using the direct reset connection.
Warning:Multiple clock statements appear in the reset loop.
and i cann't go on with my synthesis,i don't know how to correct it,pls help me.
sevid
sevid
