andro
Junior Member level 3
help with flow meter water based PIC16f876
i want to build washing machine control system, but i am confusing on a device, that is flow meter water. i saw analog one on an industrial washing machine and takes hot water from boiler and the device reads the volume and send it to control system, but i am confusing about the connection between flow meter and control system.
so i need a flow meter water and connect it to pic16f876 and i want to measure pulses coming out of meter and connecting it to pic. these pulses will be external interrupt source.
But my question is if some one has a little experience with it and tells me a one type and how to connect it or some catalogs and it should be sustain hot water with metal body .
conclusion:
need flow meter water sends reading to microcontroller pic
and so, measure the volume consumption in the washing machine
i hope you have got my point
thanks
conclusion:
thanks
