HELICAL ANTENNA.....Helppp...
rickert111
I am tryimg 2 design a helical antenna which would enhance the signal reception in your mobile phone (simply 2 increase the tower reception if u r in an area where reception is low ) ??
I am trying 2 get the radiation patterns and other such observations (Gain, directivity,lobes etc....). Plzz help..and tell me how 2 proceed ahead ??
Do reply....Its urgent.......[/b]
toonafishy
Full Member level 6
Earth
Why do you think a helical antenna will enhance performance? Helical antennas are for circular polarized waves but the mobile phone is vertical polarized.
balaguru thavamani
Full Member level 5
i think since its circularly polarised it can recieve both vertically polarised and circularly polarised waves.
in earlier days helical antennas used in mobile.Now a days PIFAs are used in mobile phones because its difficult to achieve multiband using helical antenna design.
rickert111
hey, i am not implementing the antenna inside the phone..it will be outside the phone and can be of 2-3 feets.....u can install it outside your home and it will catch d signals 4m dere ..enhance it and transmit 2 ur mobile antenna....
Added after 3 minutes:
I can also use an amplifier in between 2 increase the reception ...basically it will b somewhat like this ..
MOBILE TOWER --> OUSIDE HELICAL ANTENNA --> AMPLIFIER --> INSIDE ANTENNA (may b a wire directly connected 2 cell) --> PHONE .
pabloec
Member level 2
i think that if its going to be fixed ur better off with a very good yagi pointing towards the tower with frecuency and polarization adjusted for your specific need.
some very good yagi can be desdigned and manufactured very preciselly at least up to 3ghz.
rickert111
@ pabloec ... can u plzz suggest or post some materials/documents regarding this......
