MRFGUY
Full Member level 1
counter with 7474
I am facing sometime my counter is stuck at 0 during simple 3bits upcounter by using 7474 IC.
After I reconnect again. It is work. It is happen quite often. So I need to clearify myknowledge.
Normally I connect all PREset pins to VCC and all CLeaR pins to switch. When ever switch on the counter will run from 000o 111.
