HDL of synthesized design (synplify)
martur
hi,
i'm using synplify to synthesis my design.. but after synthesis, i don't find the VHDL netlist of the synthesized design. i don't know where to find it.
thank you in advance
you can have the vhdl or verilog netlist, but these are generated for post-syn simulation.
You need to configure the software to generate these files.
The normal procedure only produce edf file as the output.
thank you for your anwser
i know about the netlist .edf .. but i need the VHDL generated netlist. in the implementation options, i activated the option "write netlist VHDL output" .. but after sythesis, i can't find this file.. so i'm asking if there is an other solution to generate such file?? how to configure software to do it??
Do you mean the " *.vho " file, means the file after the place and route and timing simulation. If it so the file is in the project folder....
