rakeshk.r
Member level 2
HI, I am using Mentor graphics HDL designer tool. As you can see in img1.png attached, when I create a block diagram, the VHDL created by tool ends up in older version of VHDL (though not sure of which VHDL version it is). But I want it to be in VHDL 2008 version, because the VHDL files written by me are in VHDL 2008 version. I thought it would be a better way to have all VHDL files in the same version to avoid any incompatibility issues later. As you can see in img2, when one tries to create a block diagram, the user doesn't get an option to choose the VHDL version. So I want to know, is there a way to create a block diagram so that the tool creates the structure in VHDL 2008 version or atleast change its vhdl version later after the block diagram is created ? Thank you.
