xmen_xwk
Full Member level 3
I've a microcontroller generating 1Khz freq PWM and and I need to do some switching with HCT08 but the output is a single connection.
So I made 2 schematics. But I'm bit confused which one is correct.
The above one is exactly what I want but I'm not sure if HCT08 has internal diode. Because current can flow in other part as well. Does it has internal diode ?
Still, I put external diodes for some safety. But Im not sure if it will work properly or not. Because diode drops voltage and Im only using it for 3v3 to 5V. Or is there some special kind of diode that I can use ?
Thank you
Thank you
