hc05 bluetooth and pic 16f1847
Gopi Vh
hi
i used the below code for 18f4520 it was perfectly working ,but its not working in 16f1847 .I am confused what is wrong ,description about the project is
rx/dt -rb1, tx/ck-rb2, if i recieve char it indicates by turning on or off led .
I am using 16f1847 , hc05 bluettoth, android mobile app
  unsigned char uart_rd;
 void main()
PORTA =0;
PORTB =0;
ADRESL = 0;
ADRESH = 0;
 TRISB = 0;
 TRISA = 0;
 TRISB.F1 =1;
 TRISB.F2 =0;
  CM1CON0 = 0;
  CM2CON1= 0;
UART1_Init(9600 ); // Initialize UART module at 9600 bps
Delay_ms(100); // Wait for UART module to stabilize*/
 while (1)
  if(UART1_Data_Ready())
    { // If data is received,
     uart_rd = UART1_Read();
     UART1_Write(uart_rd);
      Delay_ms(100);
     if(uart_rd == 'a')
     LATB.F3 = 0;
        LATB.F4 = 0;
      if(uart_rd == 'b')
     LATB.F3 = 0;
        LATB.F4 = 0;
      if(uart_rd == 'c')
     LATB.F3 = 0;
        LATB.F4 = 0;
      if(uart_rd == 'd')
     LATB.F3 = 0;
        LATB.F4 = 0;
      if(uart_rd == 'e')
     LATB.F3 = 0;
        LATB.F4 = 0;
      if(uart_rd == 'f')
     LATB.F3 = 0;
        LATB.F4 = 0;
      if(uart_rd == 'g')
     LATB.F3 = 0;
        LATB.F4 = 0;
      if(uart_rd == 'h')
     LATB.F3 = 0;
        LATB.F4 = 0;
       if(uart_rd == 'B')
     LATB.F3 = 1;
        LATB.F4 = 1;
       if(uart_rd == 'C')
     LATB.F3 = 1;
        LATB.F4 = 1;
       if(uart_rd == 'D')
     LATB.F3 = 1;
        LATB.F4 = 1;
       if(uart_rd == 'E')
     LATB.F3 = 1;
        LATB.F4 = 1;
       if(uart_rd == 'F')
     LATB.F3 = 1;
        LATB.F4 = 1;
       if(uart_rd == 'G')
     LATB.F3 = 1;
        LATB.F4 = 1;
       if(uart_rd == 'H')
     LATB.F3 = 1;
        LATB.F4 = 1;
        LATA.F7 = 1;
          LATA.F6 = 1;
       if(uart_rd == 'A')
     LATB.F3 = 1;
        LATB.F4 = 1;
      if(uart_rd == 'S')
        {  LATB.F3 = 1;
        LATB.F4 = 1;
              Delay_ms(1000); //RCSTA  = 0x00;
hello,
16F1847 is a bit particular...*
to use UART on RB1,RB2
 APFCON1.TXCKSEL=0; //  TX/CK function is on RB2
before UART1_Init(9600);
Please Zip and post the complete mikroC PRO PIC project files. I will see what is the problem.
As you are using mikroC PRO PIC Compiler, I have re written the code using the same compiler. I have used serial interrupt to receive UART data. I think the problem with your code was the below registers were not configured as shown.
APFCON0 = 0x00;
APFCON1 = 0x00;
ANSELA = 0x00;
ANSELB = 0x00
If you have enabled MCLR pin then you have to pull it to 5V using a 10k resistor. If you have enabled WDT then you have to clear the WDT as required.
If you still want a code which doesn't use serial interrupt then I can make a code for you using
UART1_Data_Ready()
function. Test the working of my code in hardware and reply. I have compiled the code for INTOSC 4 MHz. I am not sure how stable it is and whether it can be used to generate proper baudrate for UART communication. Try sending some text from PIC to PC using UART. If it prints the text properly then you can make sure that baudrate is generated properly.
I have used INTOSC because when character 'S' is received you are turning on the pins
LATA.F6
and
LATA.F7
which also have OSCx functions.
Code
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
char uart_rd;
void interrupt() {
    if(RCIF_bit) {
        if(OERR_bit) {
             OERR_bit = 0;
             CREN_bit = 1;
             CREN_bit = 0;
void main() {
    CM1CON0 = 0x00;
    CM2CON0 = 0x00;
    ANSELA = 0x00;
    ANSELB = 0x00;
    APFCON0 = 0x00;
    APFCON1 = 0x00;
    TRISA = 0xC0;
    TRISB = 0x02;
    PORTA = 0x00;
    PORTB = 0x00;
    LATA = 0x00;
    LATB = 0x00;
    UART1_Init(9600);
    Delay_ms(200);
    RCIE_bit = 0;
    RCIF_bit = 0;
    PEIE_bit = 0;
    GIE_bit = 0;
    while(1) {
          if(uart_rd) {
               if((uart_rd == 'a') || (uart_rd == 'b') || (uart_rd == 'c') || (uart_rd == 'd') ||
                  (uart_rd == 'e') || (uart_rd == 'f') || (uart_rd == 'g') || (uart_rd == 'h')) {
                          LATB.F3 = 0;
                          LATB.F4 = 0;
               else if((uart_rd == 'A') || (uart_rd == 'B') || (uart_rd == 'C') || (uart_rd == 'D') ||
                  (uart_rd == 'E') || (uart_rd == 'F') || (uart_rd == 'G') || (uart_rd == 'S')) {
                          LATB.F3 = 1;
                          LATB.F4 = 1;
               else if(UART_rd == 'H') {
                          LATB.F3 = 1;
                          LATB.F4 = 1;
                          LATA.F6 = 1;
                          LATA.F7 = 1;
               uart_rd = '\0';
  • UART.rar
Thanks for your reply .It is not responding ,data is receiving but no led on /off .I have tried with your code also
Try using external crystal on RA6 and RA7 and see if it works. Compile the code for 4MHz XT Oscillator. Show your circuit. Have you connected PIC to PC ?
If yes, how ? What is the baudrate set in PC for the COM port used for communication ?
Try the attached project with INTOSC. RA6 and RA7 are used for LEDs. Connect the PIC to PC using a TTL2USB adapter. Set baudrate in PC to 9600 bps. The serial Terminal software should display a string. I have done changes in the way the if() conditions are used but that will not affect the working of the code.
The problem was RCIF_bit was not cleared in ISR. So, when character was received in ISR the program execution was stucking in ISR and remain there. I have now cleared the RCIF_bit in ISR. Test this and reply.
  • UART rev1.rar
hello,
RCIF is an exception in ISR treatment
RCIF can not be cleared by software (put zero in it)
a reading of UART clear this bit ...
  RCIE_bit =[B] [COLOR=#ff0000]1[/COLOR][/B];    //  must be set  to valide UART RX interrupt
  RCIF_bit = 0;
  PEIE_bit =[COLOR=#ff0000][/COLOR][COLOR=#ff0000][B]1[/B][/COLOR];  //   must be set  to valide peripheral interrupt
  GIE_bit = [COLOR=#ff0000][B]1[/B][/COLOR];  // must be set to valide every interrupt
Treat also Frame error (RCSTA.FERR) in ISR..
Yes, paulfjujo is right. I made a mistake.
This is wrong.
RCIE_bit = 0;
This is right
RCIE_bit = 1;
