kh9341101
Newbie level 1
- Joined
- Mar 21, 2015
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 13
Hi, I am a student from Taiwan.
Trying to write a verilog code for ultrasonic sensor HC SR04.
Here is my code
And I use Cyclone IV EP4CE22F17C6,
but everytime I load in the code,
The led doesn't react correcting,
it blinks and blinks...
I thought it was because I didn't give the trig and echo 5v,
but after evaluate the voltage,
it still turns out failure.
Is there any problem to my code?
Thank you!
Here is my code
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 module ultrasonic(clk,fpga_rst,trig,echo,lights); input clk; input fpga_rst; input echo; output trig; reg [16:0] t; reg [16:0] s; output reg [7:0] lights; reg [19:0] cnt; pll1 pll1( .inclk0(clk), .c0(clk_div) ) ; always@(posedge clk_div) begin if(!fpga_rst) cnt<=17'b0; else if(cnt>=17'b1_1000_1000_0000_0000) cnt<=17'b0; else cnt<=cnt+17'b1; end reg trig; always@(posedge clk_div) begin if(!fpga_rst) trig<=1'b0; else if((cnt>=20'b1_0100)&&(cnt<=20'b10_1000)) trig<=1'b1; else trig<=1'b0; end always@(posedge clk_div) begin if(!fpga_rst) t<=17'b0; else if((cnt>=20'b1_0100)&&(cnt<=20'b10_1000)) t<=17'b0; else if(echo) t<=t+17'b1; end always@(posedge clk_div) begin if(!fpga_rst) s<=17'd0; else if(cnt<20'b1010) s<=t/58; end always@(*) begin if(s<3'b10_1111) lights=8'b00001111; else lights=8'b11110000; end endmodule
Thank you!
