Hbridge using TIP41C not working
xynthian
Newbie level 3
hbridge bjt
I need a little help here. I fixed up everything and my motor is not working.
I checked the current through the transistor and there is no current flowing through the emmiter. Can you tell me what is the problem?
Attached is my circuit.
Thanks
echo47
Advanced Member level 5
USA
h-bridge using tip41c
Tell us what voltages you measure around the circuit.
How much current are you feeding into the opto-coupler?
How much current does the motor require?
IanP
West Coast
all npn h bridge
Assuming all components are OK and connected in configuration as per your drawing, you will always have some problems because of unfortunate use of 4 NPN BJTs ..
It is impossible to "saturate" both high-side NPNs driving them from the same supply voltage ..
TIP141 is a Darlington BJT and to "saturate" it you will need at least 2V Vbe, and in the same time you want the emitter voltage to go as high as possible, ideally as high as the supply voltage ..
One option to avoid this issue is to drive the high-side NPNs of higher voltage .. see similar scenario (with N-channel MOSFETs) on the attached picture ..
Alternatively use two PNPs as the high-side switches and re-configure the bridge ..
Regards,
IanP
    xynthian
xynthian
Newbie level 3
h bridge 2npn 2pnp
I supply 9 volts to the circuit. which means the opto-coupler have around 9volts.
The dc motor is a hobby one. So I guess around 9 volts should be enough.
What i meant is I measured no voltage drop at the emmiter side of the power transistor.
Added after 2 minutes:
Regards,
IanP
You mean I should change both the npn to 2 PNPs? Sorry I'm really a beginner in electronics. Thanks for your explanation.
IanP
West Coast
tip41c circuit
It's just easier to control H-Bridges build with 2 NPN and 2 PNP transistors ..
See example at:
Take a look at the TOP H-Bridge .. Q5 and Q6 can be BJTs from your optocouplers ..
Regards,
IanP
xynthian
Newbie level 3
pnp transistor h bridge
See example at:
Regards,
IanP
:D Thanks. Now I've connected my h-bridge as your circuit. But there's a problem. The positive and negative side of the anode give me a reading of 7volts. Because of this, my motor can't spin.
Why is this happening? I doubt that It's because both of the pnp transistor is on right? How to correct this problem?
