[SOLVED] Having trouble with VHDL syntax, can anyone help me please. New to forum and VHDL.
solely_magnus
Newbie level 3
Newbie level 3
these are the error messages, i don't know how to fix them.
** Error: //ads.bris.ac.uk/filestore/MyFiles/StudentUG14/aa14244/Documents/SDR Lab/shifter/shiftd.vhd(46): near "else": expecting "END"
** Error: //ads.bris.ac.uk/filestore/MyFiles/StudentUG14/aa14244/Documents/SDR Lab/shifter/shiftd.vhd(52): VHDL Compiler exiting
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
library ieee;
use ieee.std_logic_1164.all;
--additional functionality of being able to shift both up and down
--DIRUP=’1’ then DIN will shift into the least significant bit Y(0)
-- If DIRUP=’0’ then DIN will shift into the most significant bit Y(7)
entity shiftd is
    port (
        din : in std_logic; -- DATA IN
        en : in std_logic; -- CHIP ENABLE
        clk : in std_logic; -- CLOCK
        y : out std_logic_vector(7 downto 0); -- SHIFTER OUTPUT
        dirup : in std_logic); -- SHIFT DIRECTION
end shiftd;
architecture shiftd_arch of shiftd is
--SIGNALS
signal s_register : std_logic_vector (7 downto 0); --REGISTER CONTENTS
begin
--PROCESS : SHIFT
shift : process (clk)
begin
    if rising_edge(clk) and en='1' then -- FULLY SYNCHRONOUS AND ENABLED
      if (dirup = '0') then
        for i in 7 downto 1 loop
          s_register(i) <= s_register(i-1); -- SHIFT ALL BITS UP 1
        end loop;
        s_register(0) <= din;  -- INSERT DATA BIT IN LSB
      else if (dirup = '1') then
        for j in 1 to 7 loop
          s_register(j-1) <= s_register(j); -- SHIFT ALL BITS DOWN 1
        end loop;
        s_register(7) <= din;  -- INSERT DATA BIT IN LSB
      else null;
      end if;
    else null; --else null for original if statement
    end if; --for original if statement
end process;
y <= s_register; -- WRITE REGISTER CONTENTS TO OUTPUT
end shiftd_arch;
thank you but why is this what is the difference between
HTML:
else if
and
HTML:
elsif
The question demands for VHDL text book or language reference literature, I think.
else if opens a new if ... else ... end if level which must be closed by a terminating end if. But you don't have it in your code.
