Re: IIP3 calculation in ADS
alizadeharand said:
i don't want you to refer me to Advanced Design System 2009 guide page...
i just want a simple hint!
Your requirement of simulation is too easy.
So there is no simple hint better than "Tutorial Examples in Advanced Design System 2009".
See "Tutorial Examples in Advanced Design System 2009" surely.
And followings are not from "Tutorial Examples in Advanced Design System 2009".
https://www.designers-guide.org/Forum/YaBB.pl?num=1262828862/20#20
https://www.designers-guide.org/Forum/YaBB.pl?num=1262828862/22#21
As far as I see all your previous posts, you also have Cadence Spectre although you don't seem to be familiar with Cadence Spectre too.
If you use Cadence Spectre instead of Agilent ADS, can you do simulation setup of IIP3 ?
If so, IIP3 evaluation in ADS is same conceptually.
Or is there any simulation enviornment where you can do IIP3 evaluation, such as Mentor eldoRF, Synpopsys HSPICE-RF, etc.
Again, IIP3 evaluation in ADS is same conceptually whatever simulator you use.
If you have actual measurement experience of IIP3, simply emulate actual measurement setup in simulation.
Learn measurements using actual instruments. Not "EDA Tool Play".
