Has anyone install IC50 on Fedora Core 2?
qslazio
Full Member level 3
cadence unable to connect to library manager
Does everything work all right under FC2?
thanks
edacw1
Full Member level 4
cannot install ic50
I think you should install it on RH7.X, 8.0 or suse 9.0pro.
dumeHCM
IC50 doesn't support Fedora Core 2 !
edacw1
Full Member level 4
unable to connect to library manager icfb
You can install some rpm packages in order to support IC50 on Fedora.
aravind
Advanced Member level 1
india
unable to connect to library manager (60 tries)
post clearly which rpm's needed
if u dont know say clearly ,i dont know the rpm's
i think when u install fedora u must choose all package in installed,mainly software devleopment,kenel programming
then u try
exeiji
Newbie level 6
I installed IC50 under FC2 with AMD64. icfb starts up fine but I can't bring up the library manager. When I click on the library manager, it pauses for a while and then shows
*WARNING* (ddsOpenLibManager) unable to connect to library manager (60 tries)
Can someone please help me with this?
Thanks in advance!!
exeiji
Newbie level 6
hmm...so, it seems my FC2 is missing a library.
when I tried to execute cdsLibManager under ic50/share/bin, it says "Error: can't find libjava.so." I tried to look it up using yum, "yum provides libjava.so"; I have no hits. :cry:
When I tried to google it, I got whole bunch of results related to java programming or so it seems. I'm not a programmer; the last program that I wrote was in either in BASIC or PASCAL in high school.
So, please help me!! Where can I find this libjava.so??
Thanks in advance!!
tochaHCM
Full Member level 1
Why FC2. In cadence spec, IC5 only support RH7.2, RH7.3, RHEL2.1.
you are on your own if you try to experiment with FC 2
exeiji
Newbie level 6
Yes, I know IC50 doesn't support FC2. I just want to see how it performs with a 64bit CPU under a 64bit OS.
Plus, I have heard so much about Linux. Having a 64bit OS and IC50 just gives me enought incentive to jump in and have some fun or headache :D
okguy
Full Member level 6
China
Before to run icfb &, you need to enter:
export LD_ASSUME_KERNEL=2.4.1
Already stated in :
edacrack
Member level 3
It doesn't matter, the tool was compiled by 32 bit compiler, so it either won't work under 64bit OS or the performance still the same
senado
On my side it works with : redhat 7.3; redhat 9 and Fedora Core 1...It should work on Fedora Core 2...
edacrack
Member level 3
really? with IC5?
z81203
Full Member level 5
for i know, there are some problems that ic50 on fc1. a friend of mine cann't install it, but ic5032 is no problem on fc1.
so maybe you would try ic5033 or ic5141 better.
tochaHCM
Full Member level 1
IC5143 still have problem with FC2
ip-core
Newbie level 1
IC5033 can run on Fedora Core 2, just use export LD_ASSUME_KERNEL=2.4.1. I really works!
simonhcc
I install ic5033 and ic5041 in rh7.3 , and tar zcvf full directory .
extract tar file in fedore core I and fedore core II ,
it work very well....
even i use fedore core II AMD64 , it stll work well ..
jccollege
Newbie level 1
IC5XX best working with RH7.3
